Policy Application
I went and moved servers for all clients from my initial deploy policy folder to the server policy folder and the assets show the change happened but the policy isn’t applied.
If I click scripts, none of the scheduled scripts are showing and the monitoring tab is missing the monitors. When you click view effective policy it shows the initial one.
How long after changing the policy should it apply?
Basically instant. So it’s probably broken, contact support.
I’ve had that happen on a few devices, I actually have an asset search just to check for that situation. What I do is move them up a policy level, save, move them back and save again and that usually fixes it.
Thanks! I have made a ticket with support and am waiting to hear back. I may try moving them around like @shawn.goncalves mentioned depending on how long it takes to hear back.
