This is the output I’m getting from the script on a computer with a recent BSOD:
Unhealthy - BSOD found. Check Diagnostics
error> System.InvalidOperationException: A circular reference was detected while serializing an object of type 'System.Management.Automation.PSParameterizedProperty'.
error> Stack:
error> at ConvertTo-Json20, C:\ProgramData\Syncro\bin\module.psm1: line 299
error> at Call-SyncroApiEx, C:\ProgramData\Syncro\bin\module.psm1: line 251
error> at Call-SyncroApi, C:\ProgramData\Syncro\bin\module.psm1: line 231
error> at Rmm-Alert, C:\ProgramData\Syncro\bin\module.psm1: line 32
error> at <ScriptBlock>, C:\ProgramData\Syncro\bin\76ef8e67-af89-4adc-a384-486f7e4476e6.ps1: line 27
error> at <ScriptBlock>, <No file>: line 1
error> Call-SyncroApi: failure
error> System.InvalidOperationException: A circular reference was detected while serializing an object of type ‘System.Management.Automation.PSParameterizedProperty’.
error> Stack:
error> at , C:\ProgramData\Syncro\bin\c4e4fe13-c702-4a0b-b350-1af410ebba66.ps1: line 17
error> at , : line 1
@anon77823243 The forum defaults to a minimum character length to avoid long threads with a bunch of +1’s and ‘thanks’ without additional content which can make things harder to follow. See Rule #7
You can hit the little heart icon on a post to give a thanks. Getting and receive likes this way will also unlock badges
I made an update to the BSOD script that was provided by CyberDrain. For the folks that were seeing an issue, can you please import the updated script and let me know if it’s working for you now? Thanks.
This must be a dumb question but can someone tell me where the info goes from this script about the bsod? I get Unhealthy - BSOD found. Check Diagnostics in the console window. Thanks
For the WiFi Profile deployment, we have hidden networks for our internal equipment. We pushed this and it hit the machine, but not connect. We tweaked the SSIDConfig section as such:
The difference is the true which allows it to connect to hidden networks. This should not affect those networks that are broadcasting, so I imagine adding this to the CyberDrain default script would be a good idea.
