Network Scanner
Team,
It would be very useful if you can integrate a network scanner and give us the ability to push the agent installation via the scanner.
Usually, this would be done by installing the agent on a single device, scanning the network(s), saving the admin credentials in the system, and pushing the installation to all other devices.
The network scanner alone would be a big help, because if its based on the mac-address, i can see a list of Assets that dont have syncro installed and i can talk to the customer and say, hey you have new Assets that i dont know, how about Virus-Scanner? Or best all asset found are listet as Manually assets in the customers asset list so i can write down notes to each asset like this is a router, and dont need to add it manually this would complete the solution.
There is a powershell script have all the things… just run it once or twice a day.
