I forgot to disconnect a session so I could pick it up on my laptop at another location. When I try and connect to the comp I was working on, it won’t connect because it says it’s already in a session. How can I disconnect that session so I can start it from another computer? I don’t see a way. Now I have to drive all the way to where I started it and disconnect then drive back to my 2nd location.
Use the backgrounding tools / remote control as a secondary to splashtop to remote in.
In your case, you could probably also restart the splashtop services to kill your existing remote session.
Jeff’s suggestions are good! If you were using Splashtop this is something that it does. It takes a while to time out when you disconnect without manually closing out of the session.
