Mac Script Required Files
Does required files work for Mac Script?
I did the following…
  1. Uploaded my required file.
  2. Added the required file option in the script.
  3. Set the path to /tmp/syncro/ and set the required file.
Nothing seems to even attempt to download.
Works fine. Make sure your path includes the actual filename.
So /tmp/syncro/requiredfile.dmg for example.
That was it! Thank you!!
