Is there a way to save multiple customers in an asset search?
We want to push out a message specifically to our MS business clients and not our residential ones. Thank you
Do you flag your residential customers in any way? If you use a custom field or something to identify those it should be easy enough to create a saved customer search to segment what you need.
We hadn’t had a need to separate our customers like that before so separated them and are using the saved search feature. Thank you
