Inventory (Products) Integration
Does inventory automatically update both ways with QBO or will it need manual push one direction or the other?
Hi @mgustafson
QBO is not two-way sync. You can however check for Quickbooks item changes in your Syncro acount here: [yoursubdomain]syncromsp.com/quickbooks/settings incl. an attempt to import your QuickBooks Items into your Syncro Inventory,
