Ingram Micro integration
On the Ingram Micro integration page syncro was mentioned. I couldn’t find many other details on it.
Is anyone using any form of IM integration? If so, what do you use it for?
This is the website I found for setting things up. I hope this helps. I will update you on my progress
Cloud Marketplace Integrations : IngramCloud
