How Do I Either -- Upload a File as a Ticket Attachment or Parse its Contents as a Private Ticket Comment
We have some scripts that generate log files in working directory on an asset.
These same scripts also create a ticket for the work that is performed via script.
How can we accomplish one of the following:
  1. Upload the log file as a ticket attachment
    and/or
  2. Parse the contents of the log file and dump it as a private comment into the ticket created by the script
Thanks!
You can insert it as a comment using the Synco scripting module…
You can attach a file using the API.
https://api-docs.syncromsp.com/
Thanks for the pointers.
No problem. Anytime.
