How can I report on all devices with a certain application installed?
Is there a way to run a report or query to show any device that has a certain application installed?
Create a Saved Asset Search with the field Application Installed. Then go to asset audit report and select your saved search. Customize columns as desired and export.
thanks! This worked as expected
