Does anyone know how to use the timelogs API endpoint to pull more than 100 entries? It doesn’t seem to have any pagination, so is 100 entries the max? I’m trying to pull all of last years hours clocked in so I can use it to calculate tech utilization.
Hi Matthew!
Depending on what you’re using the data for, for example, you could do one call to
https://[subdomain].syncromsp.com/api/v1/customers **?page=1**
The next call to
https://[subdomain].syncromsp.com/api/v1/customers **?page=2**
…and so on. You could also write the data from each call to a file so it is all collected in one place.
