GPU model in Asset Audit Report
How do I add GPU model and GPU memory to the asset audit report? There is no GPU model that I can check in the column list in the report.
Thanks
eric
That information isn’t available in Syncro, you’d need to run a script to insert the info into custom fields you create. “Get-WmiObject Win32_VideoController” has the information you need, however from a quick test on my machine and a google it looks like Windows reports any GPU above 4GB as 4GB, so it won’t be accurate for large RAM cards. There’s another way to grab accurate RAM size, but it’s more complicated and doesn’t work right on integrated looks like so the whole thing would turn into a significant script project if it has to be accurate across the board. And even more so if you want to report multiple GPU’s properly.
