Hi,
I am trying to forward mail from customer to automatically create ticket on that customer.
The email address I am forwarding from is a user in Syncro.
The email address I am forwarding from is not a contact in Syncro.
I am forwarding an email from a customer email address that is a customer and has a contact in Syncro.
The email has the FW: in subject
Still, the email always shows up as Lead from the forwarder email address insted of matching the email to the customer.
This is a known issue ever since rich-text ticketing was rolled out. There is a temporary (god I hope itâs temporary) fix to it, you just need to remove the brackets around the âFromâ address in your forwarded email. For example, if the top of the forwarded email looked like this:
Then you just need to remove the < > around the clientâs email address. Then when you forward the email to Syncro and it looks like the below, it will find the right client:
It works with the temporary fix.
However, like @onno, my email clients doesnât use âFW:â but âFwd:â or even âTr:â (when itâs configured in french) in front of the message subject. It would be nice to have the option to change the tag that is used to trigger the forward function.
