file browser background tool is not allowing me to unzip a file to the same directory the file is located in.
i have tried it without specifying any folder, and i have tried it by giving the full path to the same dir that the zip file is located but it will not unzip
Correct. It also doesn’t like zip files with folders in them. You can report the bug to support, but in general they don’t seem to want to do much with background tools, so I wouldn’t hold my breath for it to get fixed.
