Hello to the hive mind.
What are you doing currently to locate endpoints on versions of Windows 10/11 and macOS that are older than “X” version in Syncro?
Monitor - Windows Update - Pastebin.com is what I use to alert on EOL versions of 10, don’t have any Macs to deal with thankfully. If you want to use Saved Search you can do something like:
