Delete Old Inventory Bundles
I have been using RepairShopr/SyncroMSP for many years. I have built up a number of inventory bundles that are no longer relevant. Can I delete those without messing up the invoices?
Hi Matt, I just created a bundle and added it to an invoice, then took payment and deleted the bundle from the inventory module. It did retain it, the only thing that changed is that you can’t click it on the invoice anymore. So it does appear to retain it for historical purposes.
That is fine. Since the bundle does not list the parts used, I have to type those in the description anyway. (Like when I build a computer). Maybe I’ll just delete anything older than a year.
Thank you for you help.
You’re very welcome! :slight_smile:
