Cylance deployment script failing
Anyone having trouble deploying Cylance Protect w/ scipts? Worked a couple weeks ago, now it doesn’t. The msi gets copied, but does not install. I can run the same PS command interactively and it works fine. Any ideas?
Are you getting any errors in the script output?
I’m working on launching it so that I can get error info from msiexec.
