Hi,
yesterday I ran into an issue where I did about 50+ invoices and while the webconnector tried to sync it - Quickbooks crashed so this morning I had to go into 50+ invoices, select re-sync to quickbooks - which could have been a 1min task if I would have been able to select all the invoices that had the “no sync” status (which is already in place) and then select “resync to Quickbooks”.
Alternatively it might be also a good idea to have unsynced invoices reset to “resync to Quickbooks” after 6h or 24h after a failed sync to automatically resync them.
Thoughts?
Thank you,
Frank
You’ll find that doing many things in bulk is difficult. This is one of many things that desperately need a bulk action.
