I’m testing & deploying coro.net that uses the bitdefender av agent but branded CORO & running at a lower priority layer to not conflict with other AV engines.
The Syncro agent doesn’t detect it at all. On systems that I have Coro installed on it thinks that only Windows Defender is installed. Is this one you can test & fix in the agent to detect the Coro AV?
That would be a feature request, no way you can modify the detection yourself. I’ve never heard of Coro, so I’m guessing it will be low on their todo list if ever.
