We are trying to deploy CloudRadial Agent through the RMM,is there a script.
also is there a way to a generic script to push software ( Axcient, PasswordBoss…etc) that is not available with Choco.
Thank you in advance
There are generally no “generic” install scripts, as the accepted commands will vary. However, there are some common commands that do tend to work for a good portion of things. MSI files can generally be installed with /qn /norestart etc. But a lot of times vendors require additional commands added onto the basic ones.
But this covers everything you would need to know as far as creating a script for it:
Thank you very much.
