Check box to clear an alert when you are muting it
This is a really simple and useful suggestion. We are often muting alerts that we have a handle on and need to not hear from. Then we need to separately go in and find that alert again and clear it.
This is the suggestion:
In the dialogue that comes up to mute the alert for X amount of time also add a checkbox to clear the alert at the same time.
Or by default clear the alert if you are muting it anyways. More than likely, if you are muting it - its because you already know it exist/is a problem/nothing worry about when working with the alert.
