Bulk Print Asset Labels for Customer
You can print labels for all the assets belonging to a customer (rather than print them one by one). Note: You will need to have a cloud printing service such as Autoprinter set up to use the bulk print option.
  1. Navigate to Assets & RMM tab.
  2. Search for desired customer (or whatever criteria you want).
    1. Consider creating a saved search if the assets update frequently.
  3. Check the boxes of the desired assets, or check the box next to NAME to select them all.
  4. Click Manage > Print.
This will trigger a print job of all of the assets you checked.
