Bitdefender integration
Hi Team,
would love to see a better integration with Bitdefender, also it seems that the APIs need to be updated.
Thank you
What do you mean by the APIs need to be updated? What problems are you running into specifically?
agreed! We are finding that when we remove the policy with bitdefender from the asset, it still shows up in bitdefender pan. Also many times when changing the policy the techs need to force the install with pan. Not a simple tasks like it used to be.
I’m amazed this question needs to be asked… The API is missing most asset functionality?
You cannot view/modify policies, policy folders, scripts etc. There is so many things you can do in the webUI that are just completely absent in the API. It is extremely detrimental to the scalability of the platform.
