Benefits of having syncro print asset labels?
Is anyone seeing an advantage of having syncro print a label for a new computer? We usually order stickers from a printing company with our company name, marketing message and our contact info. When we set up a new pc we fill in the the info with the asset name, company name and installation date. If someone calls with an issue and we aren’t sure which asset we have them read the sticker. Thanks
I can see a couple of advantages, but not sure they outweigh methods you may be using. Barcode, which if scanned can pull up the asset in Syncro. I don’t see this happening very often myself except if you were in a break/fix shop with drop-offs. Second is convenience, you don’t have to change anything to print a label, select it and print. We handle ours externally as well and it works for us.
