BD uninstalls Acronis
Just a heads up, BD sees Acronis as a competitor and uninstalls. Luckily, the Acronis Backup Job Health Monitoring was able to catch it and just had to push Acronis back out.
If you make your own BD package you can also uncheck remove competitors (or edit the unzipped installer config file). No way to do with the integrated Syncro deployment though.
Yep, I’m aware of that one. Seems to sometimes work anyway, but I’d rather not try and force BD on a system that may have something already on it.
