Anyone found a way to have bitdefender not care about other avs?
Anyone found a way to have bitdefender not care about other avs installed?
Once you have one attempt at an installation via Syncro you will get a BitDefender Gravity Zone package created for that policy.
Go into Gravity Zone, under “Network”, select “Packages”. Search for the company name (use the search box under the Company column header.
Select the package to edit, there is a setting “Additional settings:” Remove competitors. Turn that off.
You should still remove other AVs as they can cause issues anyway, but this will allow BitDefender to happy install.
Thanks is there any way to tell which package is associated with which computer? I seem to have a log under each company
