Any way to sort Saved Asset Searches?
It becomes a little more annoying the longer my list gets
They should be alphabetical, but there isn’t a way to manually reorder them.
Yea, just have to name them in the alphabetical order you want. For some reason punctuation is completely ignored so my go to ^ doesn’t work, but you can use numbers to sort ahead of alphabet.
I was trying to use special characters as a way to make groups, no dice - thanks.
