Alert when workstation is no longer idle
Hi all,
Can someone help me with an alert that needs to fire off when a user returns to their desk and starts using the PC again? Most PCs are idle and on the lock screen. I’d need the alert to fire off when there is activity on the workstation.
Thank you in advance!
Search the Community Library for Idle, there is one script that seems to pull that info. You could modify that and have it generate an alert. You’d have to run it pretty frequently against machines depending on how fast you want the alert to come in.
