Alert for removable storage
Hi all,
Does anyone know of a way of being alerted when any type of removable storage has been added to a workstation? I am specifically trying to be alerted when a USB drive is present.
Thank you
If all your devices are PowerShell 4 or above, you can do:
Get-Volume | Where-Object {$_.DriveType -eq "Removable"}
Otherwise, you can use:
Get-WMIObject -Class Win32_Volume | Where-Object {$_.DriveType -eq 2}
As 2 = Removable Drives
