Hello,
The invoices in our country (Bulgaria) have to be 10 digits, so I am trying to add several zeros in the field - Last Invoice Number (example - 0000000822), but without any success.
There is no error after saving the changes but the number is back to 822.
Strange is that adding zeros in the beginning is working, when I edit already generated invoice, but this is not a solution.
Is there any other way all invoices to start with zeros?
Thank you.
Most systems trim zero’s at the start so Im not surprised to be honest, however a few suggestions - none may work for you.
- Modify the invoice template so that when the invoice is printed it has 10 characters.
- Make your first invoice 1000000822 rather than having a leading zero.
We do a similar thing however not with 10 digits to identify which of our systems generates the invoices based on the first digit - for us, in your example we are never going to generate enough invoices to complete 1000000822-1999999999 as invoice numbers in my lifetime.
Best Wishes
