Add the ability to add a ticket to an appointment
Often, an appointment can be set up with a client before a ticket is created for the task at hand (e.g. the client calls and you schedule a time with them). Not having the ability to create a Syncro appointment and then later go and edit it to assign the ticket number is counter-intuitive and adds work.
Please add this feature.
