Acronis Backup Widget(s) for Dashboard
With the new partnering of Syncro and Acronis, will there be any future updates that integrate the two - so that I can see backup statuses right from my Syncro dashboard? Or will we have to continue logging into two different places?
They’ve mentioned that they want to do more integration, but haven’t said specifically what that entails.
For now, there is a script you can use to monitor the backup health. You can import it from the community library. I modified mine by giving each failure a different category so that I could do remediation based on the category.
Hi @anon31530656, we are looking into the possibility but at this time nothing is firm or decided.
Agreed. Needed.
Thanks.
